stickyjazz
98 contour se v6 atx 167km
Just had both front control arms replaced which took care of several suspension related problems. I understand that the mech had to lift the tranny couple inches and also drop the subframe couple inches to remove a couple bolts.
Today, I have electrical probs. I have lost function of turn signal, fan and relay that moves the shift lever when brake is depressed. Symptom that I experienced when problem started was buzzing sound from shroud around sterring column when trying to use turn sig or 4 ways.
Lights, radio, dome light, 4 ways, brake lights still work.
Any ideas?? I would love to get home without having to get a tow if possible.
