livelyjay
I'm pretty new to the world of the Contour, since it's my wife's car and not my own. I'm absolutely a newb when it comes to automatic transmissions. We have been having problems with the transmissions and I want to get an idea of what the problem is before I take it in to get looked at.
2000 Ford Contour SE, 100000 miles, automatic transmission
1) The tranny has a leak. When we took it in for the timing belt, accessory belt, and water pump replacement they gave it a look and could not determine where the leak was coming from.
2) The transmission has started to "slip" when putting it under heavy load. My wife told me about this and I investigated it myself. When under heavy acceleration (such as pulling out into high speed traffic) the car revs, but the transmission does not catch. Letting off the accelerator to lower the revs helps the transmission catch. It has the same feel as a slipping clutch in a manual transmission. Under light acceleration the problem does not happen.
3) Slippage only seems to happen when it's very cold out. It was cold for the past four days, which is only when my wife had this happen. It did not happen this morning and the temperature outside is a lot warmer (39 this morning versus in the teens the past few days).
4) I checked the fluid yesterday after I took it for a test drive and it was 1 quart low. I filled it last night and once again, no slippage this morning.
Any help will be greatly appreciated. It would be nice if this is just a leak problem and not a bad tranny problem. I am more than willing to search, but have no idea what to look for and where (this forum layout is a lot different than mazdas247 where I usually am).
