LoneGunman
Be Gentle I'm New Here
- Joined
- Apr 29, 2006
- Messages
- 4
I posted yesterday about a '98 Contour, 4cyl, will hardly idle, very little power. Throwing a P1383 code. I researched the code. I pulled the valve cover, is the VCT solenoid the sensor on the left (right sode of the vehicle) in the pic?
The timing belt looks good, I did the belt and pulleys around a year and a half ago.
When I did the initial timing I used a flat bar to hold the cams, if you look in the pics I have posted the slots on the cams no longer line up, now I know they are not going to be both horizontal like when I set the timing but shouldnt they both be at the same angle UNLESS I jumped timing?
How do I tell if the timing is off?
