Hi, I am new to this site but find it quite interesting
Anyway, I have a 1995 Ford Contour with a Zetec 2 Litre engine and it runs great, but the CEL started to come on recently, at first every now and then, now it comes on everytime. When I start the car and let it idle, it does not come on, but once I take off and start driving around it comes on and stays on. I checked the codes and this is what I got:
157 Mass Airflow (MAF) sensor Circuit below minimum voltage below
214 Cylander Identification Circuit (CID) Failure
327 EGR (EGRP/EVP/PFE/DPFE) below minimum voltage
335 EGR (EVP) voltage lower than expected
The car runs and sounds great with no apparant problems, the engine does not make any noises or anything, the only other strange behaviour I get is sometime when I go to stop the car will just die, but it starts right back up with no problem.
I have noticed that when it does the voltage drops sharply, is usually runs about 14.2 - 14.5 but when I go to stop it will suddenly drop to around 12 volts and the car will die. But when I start it back up its back to around the 14 area.
Any help with this issue would be appreciated.
