99RedCSVT
on what part?
on what part?
The only time I would consider cutting a spring is on a truck. Seeing how the SVT springs come to a flat bottom instead of a truck spring where is keeps the coil going, If you cut that its going to make for a horrible situation.
If you attempt to cut in the middle and re-weld, may god be with you.
do what the asians do
If anything, do what the asians do and heat your springs. You'll have a more bouncy ride but its a lot safer than cutting.
I'll be nice and break it out for you.
Cutting springs on any vehicle is stupid until you know exactly what the effects of what you're doing are known, and follow careful procedure
re-weld what?![]()
Um....biased much?
Heating the springs is dumber than cutting them, are you serious?
I'm asian and I got to admit, some asian are just cheap that's why most integra and civic roll on heated cut springs :nonono:
My apology if you consider my knowledge dumb.
I'm just not a fan of misinformation, too man impressionable people out there you know?
Join the over-dramatic group nancy.Corrected.
I have a BS, pinky ring to prove it. -J
Again with the dead-horse.Then if you're an engineer you know the formulas to calculate spring rates correct? Why are you asking opinions if you have all the answers?:shrug: Out of the 10 years I've been on CEG I've never seen anyone cut Contour springs. There has been talk but the kids are always talked out of it. You'd think with an engineering degree you would know the ill effects of cut OEM springs. Have fun bouncing down the street and killing your struts in 1000 miles.:help:
I'm a Professional Engineer. There is a reason why formulas incorporate a Factor of Safety. What the Contour.org community (engineers and non engineers) are telling you is that it is not only a hazard to you, it is also a hazard to the rest of the other drivers on the road. You may want to try asking for suggestions for "cutting springs" from other forums. I'm quite sure you won't be getting much suggestions here. It is kinda like asking how much tread I should shave from my tires so that it sticks better on the public roads.......
One thing you'd learn as an engineer is that all the formulas have to have defined assumptions. What I mean by this is that you can calculate all day, but the real-world result may be different, so I'd like to see some examples of how much someone cut and what the resulting drop was. ....-J
-J
