striker2
Official CEG Vendor
i have never been able to remove the little rubber hose from either the PCV valve or the pipe with the pipe still bolted to the block. if you can then great, however dont be suprised if you cant.thats more trouble then its worth... Jack the car up climb under it and reach up behind the exhaust manifold, the will be a hose back there, pull it off... theres the PCV valve, pull it out, replace... hook hose back up... 2 minute job, really.
