HELP!!!
68fordman
Waxahachie, TX
my car is way past due on inspection and i need some help......
97 mystake 2.5 mtx 107k
running lean bank 1 & 2....i've put on new..
1. intake gaskets
2. O2 sensors
3. vacuum hoses
still running lean...cleared the codes and everything after each....still lean... WTF is my problem...fuel pressure regulator or what or is it just something screwed up thats and easy fix....any help is greatly appreciated
Post the exact CEL codes. Check for vacuum leak (broken hoses, loose air filter clamps, etc.).
i cleaned the MAF when i optimized TB.....the CEL codes as P0171 and P0174
You have a massive vacuum leak. Check the clamps around the TB first. Then check other hoses, (near UIM, EGR, Brake booster, etc.)
Yeah its likely a big vac leak somewhere...or a bunch of small ones in mutiple hoses.
Not sure if its common on the duratec but in my Windstar, the lower plenum bolt seals degrade and create a huge vac leak and throw lean codes.
replace the bolts/seals and all is good again.
