cobrawannabe
Addicted CEG'er
No pics yet... Shields are OTW. Look at the GB thread and sign up if you want one
I moved the battery to the trunk a while back. That may be the culprit for the high temps but I don;t really think so.
i think the test for this would be the numbers on summer day:shrug:
BrApple- That was some good info. & thanks for posting your findings. I have had my KKM with the original filter (it's been cleaned & re-oiled twice) for 6+ years & I had never noticed any problems. It's nice to see that, so far, your information supports this. Thanks again for your time & effort.
-Aaron
Are there any cold air intakes which utilize plastic compounds for intake piping, rather than metal piping? The OEM style plastic boxes and thick black-rubber flex-hose's offer the best buffer against heat-soak, where as metal is one of the worst known materials for thermal isolation.
Even though PVC is not as attractive as a polished aluminum pipe, it will will be superior for maintaining a lower intake temp.
Also... if you want to do a Home Depot intake, use ABS... not PVC. Black pipes looks better than white pipes... and ABS doesn't release chlorine into the intake like PVC would.It is but in our case. That PVC pipe will have a hard time maintaining stress levels from our engine rocking back and fourth during acceleration when the pvc is hot.
It's been done and has failed![]()
