TourEnvy
Thanks for all your Help Tony2005, Im all new to this contour stuff. Thats a part ill have to get at a dealership right? cost?
			Check to see if water is getting to the PCM or VSS connector. You may be missing the "rain guard" (weather stripping) next to the windshield wipers.It still doing it! Yesterday and Today. Rain both days....????
Didn't Tony and I recommend checking the battery connection like, in October? :help: :shrug:just to let you guys know...i finally figured out what the problem was....i had a loose ground wire....tightened that little nut and all problems went away...the only thing i didn't check...
ROTFL. Yes, post number 4 and 7 on this thread.Didn't Tony and I recommend checking the battery connection like, in October? :help: :shrug:
Anyway, congrats man. I know exactly how you felt when the problem went away, without needing an expensive overhaul.![]()
