SamSVT18
Hey does anyone know the guy who works at the Korum Ford in Puyallup who owns a Red SVT contour? its really nice and was wondering if you could help me on some things on mine.... i came there once or twice.
			Well, you could check your secondaries to see if they are opening/opening all the way. That might explain the noise and lack of power from 3500 rpms (when they are supposed to open) to redline. Underneath the throttle body you will see a brass colored rod connecting both banks of secondary butterflies. Have someone in the car revving it and at 3500 you shold see it shift. It should travel about 1"-2" iirc. If it is not at all, they are probably stuck closed from the carbon build up in your intake manifold. Also, this condition usually throws a check engine light. Do you have one of those? If so go to autozone and have them scan it for free.
So I have been checking around and some ppl say it might be the IMRC. But what your saying sounds pretty close to what they were saying. But i drive my car pretty hard and dont think that a lot f carbon would build up in it. So i duno. ill have to check it when i get time...... thanks though... but the sun roof ill defenently check it out. thanks again!![]()
Instead of the little white gromment from Ford I used Chicken wire. Holds it in just fine and saved money.
