waste of money for a contour svt. Unless you have huge boost or a really high compression ratio it will do nothing for you.
Yes, it does.I've heard that higher octane fuel helps burn out the gunk and whatnot.
You can use Seafoam for that. .
FWIW, C16 (116 octane) is about $10/gallon.
i put 91 in mine 3.53 a gallon here!!
Wow. I think 87 octane here is only about $2.73. (89 is $2.83)
Correct.... pretty sure most every engine has a knock sensor nowadays
