Broken little pipe - What is it?
polackSVT
Harrison Twp, MI
I was about replace the o2 sensor and found this. Wheres this pipe going to?
That should run to the evap canister I think. IIRC, green is EGR, red is Fuel Pressure regulator, and that on connect to a hose that goes to the evap canister under the PCM / power steering pump.
Keep your sarcasm for yourself :) I'm trying to fix my beast . Can't find it ,still.
take a picture from furthur back, and where the line goes to, that might help?! I have a bunch of wires that look like that, so its hard to see in the picture where it goes to, and where the broken end should go!
no i really did go look at my car. i just added to my post.
i think im going to go look again because i think i know where it might be now.
Edit: looked again. my best guess is it goes to the evap canister located on the firewall right behind and to the left of the coil pack. or it goes into another bigger black line that goes into that.
WAIT! i know where it goes. brb.
the black line goes to the one one the fire wall. the orange one is the same as my white one. OK nvm the pics make them the same color.
your line is moved and on the wrong side of the coil pack. this is how it should be. the other part circled is where the broken line goes into.
the white line goes into this. this is the back of one of the vacuum lines coming off the UIM (intake manifold)
that white line is short. i hope this helps.
