'98ZetecSE
- Joined
- Jan 17, 2007
- Messages
- 45
(1998 Zetec SE with 128K) Does anyone know what this wire is from or where the end should go? It comes out of the slot in the firewall insulation. I found the end of it between the PS reservoir and the fender.
yes it doesGoes to the hood I believe.
Agreed.based on the location of the other end of the wire that is the one that connects to the motor mount, I do believe that the one for the hood is up in the corner more then the one you have pictured
It goes under one of the bolts for the hood hinge, I think the most forward one.
ground wire that is supposed to be bolted to the alternator bracket. i dont have any good pictures of it on my car though.
i believ it mounts to a bolt holding your timing chain cover on near the tb
I can go out to the garage and look at mine if need be but im almost 100% positive it goes to the alternator bracket. the one for the hood goes down right next to the hinge and bolts to the body near the fender kinda behind the power steering reservoir.Good God! We need to make up our mind!
xdetroitx, & striker are wrong I think. Brapple you may be correct but I'll look at mine when I get home to be sure.
yup, just looked at the zetec and it is most definitely the one that bolts to the alternator bracket. the end thats still bolted on is on the firewall. its an engine/alternator ground.Now that I looked at the pic again you might be right it doesn't look like the hood one. I forgot that this is a zetec as well, I don't think I have an alt ground from there on the duratec.
Edit: in fact if you look closely at his picture you can see both the hood ground and the windshield washer hose going back towards the hinge next to the resevoir.
