Check Fuses 25 (Door locks) and 32 (radio) in Passenger Compartment Fuse box. Left of steering column, under the dash, around where your left knee is.
http://www.contour.org/ceg-vb/showthread.php?t=8691&highlight=fusediagram
Download an Owners' Manual. www.fleet.ford.com
Nah, I usually don't use that term unless I want to describe where to locate the fuel cut off switch....don't you mean your foot by the kick panel? ....
As yes, I meant the Passenger Compartment fuse box, the one that swings down.
Maybe the radio is bad. Remove it and hardwire it to a 12 volt source and see if it works.
