Unidentified Part
mrutkaus
I found this on the ground under my '95 2.5L Mystique after I was working on it!! Does it look like anything that came from the car, and, if so, what/where?
Thanks!
Mike
Looks like the 1995 VSS cable connector. If you speedo is fine, then it is an old one.
Wow, I just replaced the VSS, the speedometer gear, and the lower speedometer cable (which fixed shifting problems), I didn't see this part anywhere, my VSS cable connector is three wires into a triangular connector...
Mechanical speedometer works fine now; previously cable had been broken.
IF it seems to come from this car, where does this white thing go? Doesn't have to be from car, could be coincidence, something else...
thanks
mike
