A/C stuck on defrost
pyrotech5
New CEG'er
i just had a new motor put in and now the a/c is stuck on defrost. if i cycle the selection knob it goes cold on a/c and heat is not a problem. it is just the doors in the a/c box are not working. are the ones on the contour electric or vacuum operated?
if they are vacuum, where is the main feed at? i think the bright mechanic that put it in forgot to hook it up or cut it because it worked before.
all of the vacuum lines originate from the same spot on the UIM, I would inspect the vacuum lines as they tend to get very brittle.
also next time please post troubleshooting posts in the trouble shooting forum, this is not a maintinence post as you are not asking how/about/etc to maintain your duratec but trying to solve a problem that you don't know the answer to which is a troubleshooting post ...
