I'm currently installing a Clifford Avantguard 4 in my 99 SVT.  I have all of the connections involving the remote start hooked up to the Alarm and the Intellistart.
I have a relay set up to bypass the clutch using a - trigger on remote start to activate the relay. I have a PFK-1 transponder bypass installed to bypass PATS.
Looking at the Cliffnet software, the diagnostic in/out is all good. No hood, doors, trunk, or anything else open. I double checked the parking brake connections, and they are correct.
When I start the car with a key, the car starts. Then, I press the * button on the remote to try and activate the manual transmission mode. The parking lights flash twice, and I hear the clutch bypass relay engage. Then, the parking lights flash again. It's like the parking lights do a double flash, pause, single flash. (I try to start the car from cliffnet, and it does the same thing with the parking lights.) When I turn the ignition off, the car dies...it's supposed to stay running until I arm the alarm
According to the Avantguard 4 install manual, three parking light pulses (which I'm assuming that's what it is doing), says to check the ignition wiring. I've looked and looked and cannot figure this out.
I have it hooked as follows:
WHT/BRN (from AG4 ) -- Ignition wire(key side) GREEN on car
GRN/BLUE (from AG4 and IntellistartIV) -- Ignition wire (coil side) GREEN on car
Since I can hear the clutch bypass relay click when I try to activate "manual transmission mode", I know that it is probably not that. From Cliffnet programming, I can turn on/off the ignition, so I am assuming that this wiring is good. Is there something that I need to do that I don't know about?
I appreciate all the help I can get.
