IRingTwyce
I ROCK at bumper cars!
Like the title says, I need the easiest way.  Damn car still won't start.
			Check if there is power to the PCM by turning on the ignition to on, the CEL should come on for a few seconds. If it doesn't, there is no power going to the PCM. Also check ignition and main power fuses in the Power Distribution Box next the the battery.
Make sure the connectors are in tight for the ignition coil, Camshaft Position Sensor and Crankshaft Position Sensor.
