I need to buy a MTX-75 transmission. As I understand it, ALL Contours regardless of year or engine had a MTX-75 for manual trans. I understand about the rod/cable difference. True or False?
If you're just dropping in a used transmission, try to get a 2000 because they have roller bearing shift forks and shift smoother than the older transmissions with brass bushings.
