todras
Pretty fly for a white guy *cowbell*
Las Vegas, NV - In one of the most widely anticipated announcements for Lexus IS enthusiasts, Lexus today unveiled some of the the new 'F-Sport' line of accessories. Items on hand included 2 versions of F-Sport Brake Upgrades - one version features six piston fixed calipers, and drilled cast iron 355mm diameter rotors with a patented internal fin design mounted on anodized aluminum hubs for the front system, while the rears feature four piston fixed calipers and drilled cast iron 345mm diameter rotors. Braided stainless steel brake lines and low-dust performance brake pads are included.
The other brake upgrade on hand was a new carbon-ceramic brake upgrade. The ceramic rotors measure 380mm diameter front and 355mm diameter rear on anodized aluminum hats. They incorporate the same internal cooling vane concepts as the F-Sport cast iron rotors, while significantly reducing unsprung and rotating mass compared to the IS F stock brake system. Kit-specific performance brake pads and stainless steel brake lines are included.
F-Sport 19" forged wheel:
F-Sport Carbon-fiber engine cover:
F-Sport Air intake system:
F-Sport rear chassis member brace and sway bar set:
F-Sport clutch
F-Sport Lowering Springs and Bilstein Shock Absorbers:
F-Sport clutch
