PDXSVT
I know I'm interested in a single one, but might be inclined to go with the PVC/VC set up instead. So does that make me a half for each of the two choices?
			put me in for the dual setup for 70$. and pole, can you give me a price quote on your front and rear filled mounts too? thanks.
so any update on the bracket or pics?
I do have one question about the setup. Is this going to flow enough air to keep the crankcase vented well enough? I know its definitely good to get the oil out, but if there is too much pressure created by the filter, that's not good either.
Considering it's designed for filtering the CFM associated with compressed air, i have no reason to believe it will be insufficient for the flow of a crank case vent.
