LightningFastFord
- Joined
- Jul 12, 2007
- Messages
- 51
yup.. everything checked good.. the wheel bearing was bad.. but we'll see if that fixes it or not.. luckily that was under warranty since it was just recently replaced..
check the condition of your lower control arm bushings, I bet they are worn.
I had a horrible vibration when braking over 60 mph on the highway in my Mystique, replacing the front brakes took half of the vibration away and new control arms took care of the rest. it was so bad the dash was vibrating :shocked:
BINGO. The point 4 bushing (lower control arm rear bushing) when worn out makes the car VERY senstive to brake torque variation, which can occur normally, even with new brake parts. Replace the arms/bushings and everything should be back to normal.
did you just check the LCAs or did you actually replace them with new ones?
if you just checked them how did you do it? im still leaning towards LCA bushings.
ok.. wheel bearing was replaced.. still had the vibration.. so then they turned the front rotors.. they said they were damn near perfect even before they put it on the lathe.. but it STILL has the vibration.. im at a loss now..
nevermind.. called Bill Jenkins and he got me a great deal on the LCA.. very nice guy to deal with..
well that wasnt it.. guess i need to look again at that wheel bearing.. (even though its already been replaced..)
after rereading through everything it sounds like he may have replaced them.
