So back to my brakes after a no go on new rotors, greased pins and new pads.
Like i said before, when coming to a complete stop, the brake pedal will buzz or hum or jump, depending on the day. It'll do this for around a second and then be over with. Sometimes when letting off the pedal and then going back on it will do it on the upward and downward motion of the pedal.
I already checked the calipers, they depress fine. My dad seems to think that it has something to do with the abs thinking the front brakes are locking up when they are stopping, causing the pedal to jerk around. My only issue with that is that i am unsure if the car even has abs. (2000 SE, 4 cylinder, rear drums) Nothing seems to be giving me a clear indication of abs or not. (Manual says what should be there IF you have abs.)
I've rolled the car to a stop in neutral, so i know it isn't anything transmission related and I've stopped it with the parking brake alone, so i know it isn't the rear.
Any help is appreciated.
