projectSHO89
Finally found my intermittent vacuum leak - the two manifold vacuum hard lines are leaking where they connect to the intake.
Anyone happen to know if there's a replacement grommet or seal that will keep these little buggers from leaking again?
If so, part number and a replacement procedure? I did my UIM/LIM gaskets a few years ago so I know how to do the hose disconnect, just need to make the joint leak-tight.
Steve
Steve
