CSVTturbo
Could I get 14psi off this kit if I change the spring out? Also by doing that would I be able to make 425hp-500hp? I would appreciate the help. Thanks to all.
Could I get 14psi off this kit if I change the spring out? Also by doing that would I be able to make 425hp-500hp? I would appreciate the help. Thanks to all.![]()
http://www.nautilusperformance.com/catalog/i18.html
I am sorry it would be this kit from nautilus and running a 3L hyrbid from on 01 escape.
Boosting a 3.0L hybrid is a big NO NO! Putting the 2.5L heads on a 3.0L block raises the compression to 11.2:1 which is not boost friendly. I wouldnt put any boost to that motor unless you want a engine meltdown.
I think he is referring to a 3L Escape/Pistons with SVT upper/lowers.
It would be the same setup that Tom(Warmonger) made in this car..
So oval port heads with SVT intakes? If thats the case, then thats fine. But generally, the term 'hybrid' is the one we all know about thats great for N/A.
Why don't people say full hybrid (3L block + SVT heads, cams, UIM, LIM), partial hybrid (3L block and heads + SVT cams, LIM, and UIM) or non-hybrid (3L block, heads, cams, intake manifolds) swap. This would make it a lot easier to differentiate? Personally I feel if the swap uses a noticeable amount of parts from each motor then it should be considered a hybrid.
I've coined the term 3L ovalport-hybrid to differentiate and ovalport longblock ported to accept Split port cams and intakes, either SVT or SE.
So a and SVT 3L ovalport hybrid is just that, etc.
A full ovalport is just that, and an ovalport with SVT or SE cams is well, an ovalport with SVT/SE cams.![]()
So back to the hybrid vs COP thread...we were talking about an actual hybrid and not an 'oval port hybrid' correct?
