red brake light
98TredSVT
Plainfield, IL
What does this light mean? My ebrake is not being used and the light is on while I drive .This came on after my koni kit was installed.
It likely means that you've got a low fluid level. Check the resevoir. If it's low, you've got a leak somewhere. Check each wheel well carefully. If you have to add fluid, be careful that no debris falls in the reservoir when you open the cap. Use DOT 3 brake fluid.
FWIW the rear ABS lines should never be touched unless removing a rear hub for a wheel bearing replacement. To remove a rear strut assembly all you need is a 10mm for the top bolts, an 18mm for the main strut to knuckle bolt, and a 15mm for the sway bar end link. Undo the 18mm and 15mm end link nut then pound the knuckle down off the strut with a 5 lb hammer. When done then undo the 2 top 10mm and pull the assembly out with your hands. Takes about 15 minutes to pull a rear corner. When reinstalling put 2 top bolts in then lift the strut on the perch. Put some lubricant on the bottom of the strut and jack the knuckle back up the strut while pounding the side of the knuckle witht he 5 lb hammer. Install 2 18 and 15mm remaining bolts.
