Hello everyone, I am new to this forum, but not new to repairing cars in general.  I just need some helpful advice.
I just obtained a svt contour from a friend of mine and I am trying to get it up and running.
The starter turns the flywheel when I try and crank the car but I dont get any spark to the plugs.
I have replaced the Crank sensor and the Camshaft Sensor. I have checked to make sure when the key is in the ON position I am getting voltage (6v) to the wire from the #4 20 amp fuse to the coil. However it seems I am not getting anything out of the coil. I have tested the coil using the resistance test on all coils and they check out fine. I have an OBDII reader and I am not getting an DTC codes. So I am kind of stumped. Is there a way to jump start the coil to get spark to my plugs manually? I have checked all the connections a few times and they are all plugged in, except on cannon plug connector near the coil. It looks like a 2 connector plug. I can take pictures if that may help.
Thanks!
Thanks!
