95_Mystique
How much different is a 95 Zetec from a 00-03 Focus Zetec??? will the turbo kit work???
Its not a bolt on kit. You will have to modify it. I dont know the extent of it since I dont own a zetec, but I know that the turbo manifold doesnt fit. Im guessing the intake piping is all completely different as well due to different packaging constraints.
I supposed if it did fit, you would expect it would be advertised for a contour as well.![]()
ive been hearing mixed things about these, I just looked at a header on zxtuner.com which fits all of the focus Zetec motors and the 95-00 Zetec motors.
Which means that the bolt pattern is the same. If it bolts to the focus zetec it should bolt to the silvertop contour zetec, which does not surprise me.
Im pretty sure Hector had to modify his Focus header to fit his contour.
