I was at the local junkyard when I found a Mystique with a "Pursuit Pro 9230" alarm. The date stamped in the plastic indicates it was from 94 (mystique was a 95.) I was assuming this was a factory install but upon closer inspection and location of the unit it was not.
It was taped horribly with electrical tape to the backside of the plastic panel right below the steering column (not the actual column but the panel that has the little drop down cubby hole.)
Anyways, I pulled the alarm box, the harness's, dash indicator light and the "shock sensor" that was plugged into it. Now, the front engine bay was tore up and I did not see a horn, so I figured one from Advanced would work. And of course, there was no transmitter remote.
Now my question is this, is this alarm worth putting in? Can I find replacement transmitter and a cheap horn and have a cheap alarm? Should I just buy a new complete set? I don't plan on keeping the car longer than another year and I figured an alarm would add a bit of value. There has been some recent vehicle thefts in the neighborhood and I am not looking for a remote start and all that. I just want something to wake me up at night, or atleast to scare them away.
