The 2.5L Duratec has an oil starvation problem on high RPM (really high I've heard) long sweeping right hand turns, like an on ramp. Some people think it's the baffle in the oil pan, Ford updated this and made a better baffle pan that most people use on 3L, there are like two other thoughts on what causes it though and someone will tell you I'm sure. The common thing is to fill your oil to a little over the full line, about 6.5 quarts, do that and you shouldn't have a problem, just don't take any sweeping right handers at like 6K and you'll be fine.
