I've looked this over several times and I am certain I have accounted for all the openings in the intake. However, I have a very, very strange problem - possibly related to the IAC? The car idles a bit high. I'm currently running the stock SVT tune and it sits at 1200 RPM or so - not sure if that's normal since effectively the butterflies for the "secondaries" are open with this setup compared to what the ECM thinks it has. But the real problem is that when driven, it behaves as if the throttle is stuck. So, I drive along at 2K RPM or whatever, then stop, let off the gas, and the revs climb to 3K or so - just as if I never let off the gas pedal. It will sit there for a loong time at that RPM. If I load the motor, it will reduce the revs, but not all the way. If I let it sit, it will eventually come back to 1200 or so. But apparently only if I'm stopped. I coasted (in neutral) 2 miles at a very slow pace (20mph) and it stayed at 3K RPM. But every time I try to get out and open the hood to see what's up, it drops the revs. So, it seems like maybe there's something about the car being in motion?
Oh, and the throttle will also "stick" with the car in gear with clutch out - so if I accelerate, then let off, it does slow down, but it will drive itself at 2K RPM or so. Not good.
BTW, cruise control cable is not even hooked up (won't reach with current bracket). And I have the extra (linear) throttle return spring on there too - the accel pedal is actually fairly hard to press now. And EGR is connected. Headers installed in place of stock exhaust manifolds. All exhaust is hooked up and both pairs of O2 sensors are connected. I'm using a Taurus throttle body and upper intake (escape lower).
Apparently something is giving the motor more air than the throttle, but it is somehow linked to the throttle? Like I said, I've checked for vac. leaks, can't find any. I had one before, that I could hear, but I found it and plugged it (it was that lower hole in the accordion). I can't imagine that the IAC, even fully open, would let in enough air to get the motor to 3K RPM. This is a very annoying mystery...
