Unless you have a dirty system, a water only flush is fine. See how much sediment you have when you drain the system. If it is clean and bright, don't worry about any chemicals. If it needs a flush, the Prestone fast flush works well. It is citrus based. If you do use any chemicals, a thorough flush is even more critical to get the chemicals out.
