Ronan
Howdy all. Wondering if anyone can help?
My car is hissing air around the IAC, around the blanked off circle, which is at the back of the IAC (as your looking at the engine with the hood up).
I figured the IAC was faulty, so I bought a brand new one from Ford, and replaced the gasket. The hissing, and air leak is still there, although not as bad.
The effect on the car is, choppy idle when its cold. Once warm, its fine.
What are the odds this new IAC is faulty? Is there something else wrong which is causing abnormal pressure in the intake, causing this air leak? Any thoughts?
Thanks in advance.
Ps, I drove the car today with the heat shield, and it certainly does make a difference
Thanks in advance.
