My car is a 96 Contour GL 2.0 Zetec ATX
I have many problems occurring currently. So much that I'm even afraid to drive it long distances. I believe many of these can be fixed from one solution.
Here I go...
1. While driving my car shudders between 2nd and 3rd gears. When going from Overdrive to 3rd it bucks violently unless I give it more gas. For instance when the terrain changes to an incline while I'm driving in O/D, and my throttle position remains the same, the bucking will occur. Usually it's so bad that I slam it into 2nd just to keep it from bucking. One night, while it was bucking bucking around like a mustang, the CEL (which is always on) began to blink in one second intervals, which I found out meant the engine was misfiring. I just recently replace the spark plugs, but did notice some (not major) wear and tear on the second spark cable.
Now, keep #1 in mind while I explain #2 because I believe they are similar.
2. While replacing spark plugs, I noticed the plugs and chambers covered in oil. This really wasn't a big deal to me, because I've been having this problem for a while. However, thinking my transmission fluid was low, I wiped the dip stick and noticed traces of oil in in the fluid! And it was extremely high. Seeing this, I checked my oil dipstick, and found it was three quarts low after just having an oil change. So I'm theorizing, could the three quarts have gone into my transmission? I didn't notice any transmission fluid on my oil dipstick.
These are my major problems, now for some electrical fun.
3. My backup lights don't light up. I've read on here to check the switch, but I have absolutely no clue where to find it, and Chilton doesn't explain it very well.
4. Only the top half of my defrosting grid works. Not that major of a problem, but since I live in Michigan, it can be a nuisance.
5. The air only blows through the defrosting vents. Again, I've seen this on the forums, but I don't know where to even began looking for vacuum leaks and the such.
This was a $700 car, and I've fixed nearly half of the problems I've had. This is my first true car, (besides a $3,000 Lemon) and I've grown attached to it. I hope you guys can help. This forum has helped me out so much before, and I just now started an account.
Thanks!
Here I go...
Thanks!
