IRingTwyce
I ROCK at bumper cars!
Got the wiring harness sorted out (pretty sure anyway).  Still wouldn't start, so I figured I'd go ahead and change the plugs.  Pulled the first two, only to find them completely covered and dripping with oil, all the way up the threads.  Cyls. 3 & 4 were nice and dry.  Shining a light down into 1 & 2, I can see the oil pooled in the cylinder.
A little searching on the old site indicates this is probably just a failed valve cover gasket. This thread suggests a new gasket and "plug bore seals (like o-rings)." I have never heard of plug bore seals.
Has anyone else had this problem? How is the best way to get the oil OUT of the two cylinders once I've gone to put on the new gasket? Should I try sticking a rag or paper towel down the plug hole and soak up what I can? Any suggestions here would be greatly appreciated!
