ok, swapping out the SE radiator in my contour today for a SVT one as well as changing the water pump and I found oil in my coolant.  I have no evidence of coolant being burned in the engine.  The waterpump was leaking from one of the weap hole so my coolant level has dropped alittle in the last month or so.  It was slightly above the full mark and now its at the full mark.  I see the ecidence of the leak on the front roll restrictor.
So it is my belief that the SVT oil cooler that I installed has failed and is letting oil into the coolant. I am going to hopefully either remove or replace the cooler today.
any thoughts?
any thoughts?
