bad vibrations
my98SVTturbo
Hampstead, Maryland
alright well ive noticed a vibrating in the car when ever u turn it on and it itles it seems to vibrate really bad. recently around june my clutch went out nad i had to put a new one in. since doing that there were no vibrating isuses for a few days after the clutch was put in. im having over heating problems due to a cooling fan that went out so im going to be fixing that in the comming days. my question is...what is this vibration really commin from? or is it realted to the cooling fan problems? i dont know please help me out guys.
Thanks
Alex
Thanks
Alex
Is the engine running rough? If the engine is idling smoothly, I'd check out the front and rear roll resistors (motor mounts) If one of those is torn it lets the engine move around too much.
They only make an insert for the front roll restrictor, not the mounts or the rear roll restrictor. I just ordered a poly rear RR from Pole120.
well since there seem to be no aftermarket motormounts availbe what are the costs and part numbers of the OE SVT mounts?
Check bat for OE replacement ones and an insert http://64.202.180.37/files/cdrive.pdf or you can try Bill Jenkins or the like. Either way I'd pull yours out and look inside them to see if they actually look damaged. Then you'll know for sure if they're the problem and you can also pinpoint if one or both need to be replaced ;) They don't take all that long to pull out, maybe a half hour each once you have the car up. I'd take one out at a time and you shouldn't have to worry about supporting your engine.
will do...im takin it down to my dads shop in a few day for the cooling fan and sensors to be put in. so we`ll take a look at those i guess while its up in the air and just order it through a local dealer. thanks guys. I hope this is the problem!!!
-Alex
