Junkyard
96MystiqueGS
Wilkes-Barre, PA
I know it's short notice, but I will be making a junkyard run tomorrow morning. If there is something you are looking for, let me know and I can grab it if I see it.
Matt R: I am going to try to find the rest of your stuff tomorrow, if there is anything else, post it here.
All in all, not a bad day. i got almost everything I set out to get. I was surprised to see that no 98+ Contours or Mystiques had headlights left, even more surprising was no pre 98 headlights either. There was one set of pre 98 Mystique lights though. It was so hot that Harry's had a guy driving around in a truck with a bottle of water misting people in the face.
Matt R: I'm pretty sure I've got everything for you... 2 axle nut covers, 1 washer nozzle, 2 caliper bolt covers, OD switch with extra long wires, AC low pressure port cap. Couldn't find any trunk struts though.
Redneckboarder: I've got a DPFE from an SVT for you. I think it's a 98, but I'm not sure. Luca would probably know, it's the silver frost SVT. Didn't get the rear toe control arms... I came across quite a few that were bent from bad rear end accidents and the other few good ones were stuck on via rust. If I head out again I will see what I can get. I will PM you with details.
Trunk lid struts. I originally had a trunk w/o a spoiler, but then swapped lids with a spoiler. Now the trunk won't stay open very well.
I'm also looking for an updated cupholder, if anyone can find one cheap in a junkyard. And a lower timing belt cover (plastic piece), regardless of if it's used or not. When my timing belt went, it punched a hole in this piece, and I've never fixed it.
