hello
I am driving a 1999 contour SE with a 2.0l 4cyl zetec engine with 112,000 miles on the car. I was driving the car and the check engine light came on and i noticed i lost some power getting on the on ramp of the freeway. Regardless, I made it home and turned the car off and came back out about an hour later to take it to auto zone and the car would not start. It turned over but would not start at all.
The error i got from the check engine was P1381, Cam Timing Advance is excessive.
I took the cover off of the timing belt and found that the belt is shredded. When i turned the car over the timing belt did not even move, like it was seized up.
My question is do you think if i have a mechanic fix the timing belt the pistons could have cause damage to the engine from me turning the car over. The second question is do you think I need to change the cam and crank sensors when they change the belt. Any advice would be helpful.
Thanks
Ken
Thanks
Ken
