fliking interior light
the ice man
Be Gentle I'm New Here
Stoneham Québec
my interior light flick on and off my contour is 95 LX 2.5l i take the door swicth the complete fuse box that came with the relay and timer from my 96 gl and i check the dimmer swicht OREO button that's change nothing i cleaneup all the contact connector also the cruise control d'ont work and under hood light if someone in this planete have this probleme before its the fist time i dont find a electrical problem dont have remote starter & buglar desaperation!
You have an electrical/wiring problem. If the interior lights are flicking on and off, I would suggest you check the headlamp switch first. There is a recall 99S14 on the switch. If the recall has been done on your car, it costs about $70 for the parts.
Edit. Headlamp switch recall
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1172316&Forum=trouble&Words=headlamp%20switch%20recall&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=1year&Main=1172187&Search=true#Post1172316
