forceflow2
Be Gentle I'm New Here
- Joined
- Jul 21, 2007
- Messages
- 2
I am having an issue with my warning chime on a 99 Contour SE. If I open the door with the headlights on, there is no warning (and I am forgetful :shrug
. I looked in the manual and checked the fuse, which was ok. In fact, the key-in-ignition warning chime, which is on the same fuse, works absolutely fine (and I assume that they use the same chimey-generator, that's the technical term) so I don't think that it's gone bad. The only thing I can think of is that I had my headlights replaced, but I am unsure how that might affect it, if at all. Any ideas would be appreciated, as I have already had to have a couple of jumps because of this. Thanks.
