twocontours
95 contour 2.5L with check engine light on. Stored code is 332. KOER test shows 332. Suck on EGR and engine stumbles. Vac gauge on EGR control hose shows 6" vacuum during KOEO test cycle. Cleaned EGR valve and passages, Replaced EGR position sensor (DPFE) but it didn't fix it. Disconnect DPFE connector and run KOEO test and get 337 so the wiring checks out good.
I give up, what should I do next.
