rear sway question
chinaski
san diego
im considering purchasing a BAT 21mm rear sway and read in the FAQ that i should upgrade the endlinks and found a set on CTA. anyone know if it would be fine to use the 18mm rear sway bushings and endlinks with a 21mm rear sway?
you need the correct size bushings for the bar ... so you need to use bushings that will fit the 21 mm bar ... I don't think the size of the bar will have any effect on the end links but you will want to replace those bushings also while your at it
anyone know where i could pick up a new set of bushings? i checked CTA and BAT, non offer the correct size bushings.
