PurpleMystique
Here are some pictures I took when I did it.
I used aquarium tubing from Wal-Mart and wrapped the end with tape to make it the proper diameter to fit in the vacuum hole. Do one at a time, you might have to open the throttle a bit to keep the car from sputtering and dying. Also, be sure the wind will take the exhaust away from you. Breathing those fumes will give you quite a headache.
