CONTOURCODY
- Joined
 - Apr 27, 2003
- Messages
 - 73
I've attached some pictures. Tell me what you think is the problem(s).
Correct.....Not a head gasket problem, thank god. Damn glad I'm a member of this site. Thanks guys!
So I'll definitely do the valve cover gaskets.
I'll check on the power steering pump, A/C hose, and the front timing cover over the weekend.
All of those combined would be less expensive to repair than a head gasket fix, correct?
Mine had a leak that look like the pic of your oil pan. I just found that it was leaking from the oil filter that was 2 full turns from being hand tightThe oil pan probably is leaking. To me the majority of the oil is coming from above the pan gasket. Clean the oil mess up and try to see where most of it is coming from. Good luck.
Autozonelink. Figure 4. Left hand crankcase ventilation tube.Well I noticed something new today.
As I was removing my stock intake, I noticed that the MAF had oil on it. Then I saw the entire inside of the piece from the throttle body to MAF was coated with oil.
To me it looked like the oil was coming from the tube that connects under the plastic shield on the front of the engine.
Is that possible? And what is that tube?
