need input...pictures included
CONTOURCODY
I know I have some suspension issues. So I finally got under there and checked out some things.
I'm fairly sure I need new rear end links and bushings. But I'm sure some other things need to be replaced.
I've attached 4 pictures of my suspension.
Please give me your input as to what you see needs to be done in these pictures.
If your control arms are in that bad of shape I'd also look at the ball joints, stabilizer bar bushings and the insulators for the engine craddle/crossmember. When I replaced the control arms those items were in desperate need of replacing to.
That's what I was thinking too.
From that picture, can you tell what style control arms I have?
To me it looks like the single bolt style. But getting confirmation would be great.
On top of the complete control arms replacement, I do plan on getting all new front and rear bushings and links for the sway bars.
And now that you mention the insulators, I'm thinking I most likely do need those as well. After looking on fordparts.com, I need to get two different insulators, correct?
Definitely 2 bolt. Definitely
and for the question on the insulators I believe there are 2 in front and 2 in the back, It's been a few years since I replaced them so it's kind of hazy. I'd check with the dealer and see what they pul up.
The 2 bolt style arms are less expensive than the 4 bolt arms, correct?
In my 2nd picture, that's the tie rod, correct?
Can you tell by the picture if I need a new bushing on there?
That would be the rear trailing arm. They look ok. Tie rods are on the front and no bushings in them. Would make steering pretty soft. LOL!
