a
a
the main problem with the 1000.1bd is that the power supplies are only rated at an 8 gauge input, therefore you are constantly battling power supply failures. I have seen many amplifiers such as these come back to my store with this problem. If you are looking for a good amp to power this sub i might suggest an alpine pdx 1000.1. Even though the amp is only 2 ohm stable as rated from the factory, we have used them countless times in a 1 ohm atmosphere with no problems but you need to realize that the sub isn't 1 ohm stable it is 1 1/2 ohm stable.
