DyComet
I'm going to end up doing that.  I havn't had a chance yet to do it since I've been extremely tied up at work.  I'll give them a call today and see if they have any ideas and see what they can do for me.
			That would be cool if it worked that way in hot areas (like Phoenix). With the a/c on (in mid-summer), I used to hit around 235-240. Now I'm around 215-220. Reduction of temp is from replacing the SVT water-oil cooler with an air-oil cooler, and running waterwetter.max temp should be where the fans kick on and the coolant temp comes back down to the thermostat temp ... so stock the fans should kick on when the coolant temp hits 212F and bring it back to 190F ...I really shouldn't get much higher ... I would say over 225 is pretty high ...
Surprised Demon has not weighed in on this. 160 degree T-stat FTW! I'm using one with 50/50 Dexcool/distilled water, fans programmed on @ 195 degrees.
Demon says....
Originally posted by mcon99: "I think stock the fans don't kick in until 180 or so?"
Oh it is MUCH, MUCH worse then that!!!
Primary fan comes on at 216 and the secondary at 224. Stupid!!!
BTW - the PCM starts pulling timing at 200 degrees. 20% by 210, 40% by 230
Programmed in heat soak!!! Absolutely asinine Ford!!!
... The SVT radiator combined with the 60/40 water/dex-cool mix and some water wetter works just amazing for heat control!
Where are you guys getting the 160 degree t-stats?
Electric temp senders/gauges are notoriously poor. If you mount the sender on the block, the vibrations from the motor can kill them prematurely. Mount it remote OR use a mechanical gauge.
Also, as pointed out oil cooling has an effect on engine temps too.
Simplified but here is Newtonian cooling:
Q=h*A(To-Ta) where h= heat transfer coefficient, A is the surface area, To is temperature of the object and Ta is the temperature of the ambient. oh, and Q is total heat transfered in watts.
So if you look at it, the bigger the temp difference between To and Ta, the greater the amount of heat transferred through the object in the same amount of time. This makes the cooling system more efficient...back to that fans run less often and load the engine down less, wear out components slower.
You're assuming that there is little/no ambient airflow over the radiator to bleed off heat below the temp where the fans kick on. I commute 38 miles every day, so I get plenty of airflow & rarely hear my fans kick on excpet on the hottest of days - and/or when I run the A/C. In typical stop & go traffic or idling in your workshop you may have an arguement, but on the highway the 160 T-stat rulez.
Terminology nitpick. Yes, I've had heat transfer and thermo classes. Temperature difference is the driver in the equations, the greater the temp differential, the greater the heat transfer. That will not change the efficiency of the system. The radiator isn't magically more efficient because it's starting at 180 versus starting at 160.So if you look at it, the bigger the temp difference between To and Ta, the greater the amount of heat transferred through the object in the same amount of time. This makes the cooling system more efficient...back to that fans run less often and load the engine down less, wear out components slower.
And now a question - say I replace my thermostat with a 160 degree one, versus the standard. If I don't change or tune the ECM code to turn the fans on earlier, then what does that hurt or help?
The thermostat opens earlier, and I get more passive radiator cooling because I start flowing coolant earlier? Will that have any positive effect on horsepower / timing / whatever?
