Mark T
Some of may have seen my post in the pictures bit about me fiting a 3L hybrid lump into my ST24 Mondeo (if not, well I've umm, just fitted a 3L hybrid lump into my ST24 Mondeo, LOL)
Anyway, it's all done now & is up & running so I took it to get the Unichip remapped today. I was a bit shocked to see it only made 206bhp & about 196lb/ft torque.
Here's the spec of the engine:
ST220 3L Block
ST200 Heads, ported/polished with 3L Vv's fitted
ST200 Cams
ST200 Flywheel (lightened to 16lb)
ST200 19lb Green Injectors
ST200 Modified Wiring Loom
ST200 Upper Inlet Manifold
ST200 Lower Inlet Manifold
ST200 Throttle Body (Optimized)
ST200 Mongoose twin exit exhaust
MSDS Ceramic Coated Tubular Headers
Custom stainless steel Y-Pipe & de-cat
Techniclutch Stage 1 'Fast Road' Clutch Kit
Blitz induction kit with 5 large cold air feeds
75mm Pro-Flow MAFF
CTA intake pipe
Unichip
EGR Valve removed & UIM blanked
Throttle Hang Mod
Magnecor plug leads with Denso iridium plugs
Underdrive power steering pulley
Dual Mass Damper
Polyurethane bushed front & rear engine roll resistors
The guy I got the basic engine/heads off had a dyno print showing 290bhp but it did have Buckshott Motorsport UIM/LIM (with no secondaies)/TB but was set up on a standard ECU & was running 17lb injectors & a massive K&N air filter
So I guess what I need to know guys is does this sound right to you?
Is it likely I am loosing 80bhp & around 40lb/ft torque by putting on ST200 inlets?
ST220 3L Block
ST200 Cams
75mm Pro-Flow MAFF
CTA intake pipe
Unichip
Throttle Hang Mod
Dual Mass Damper
