SoboDave
Be Gentle I'm New Here
I am trying to replace my Axle Half-Shaft because of a bad CV joint. When I tried to get the bolt that holds the Tie Rod on, it was corroded and I ended up stripping it. I decided to cut the bolt off with a hacksaw, and then replace the Tie Rod End. Now I can't get the Tie Rod End off. I have a long 24mm wrench on the Tie Rod end and the longest 15 mm wrench on the Tie Rod itself, but it won't budge. I'm afraid I'm now stripping the 15 mm groove in the Tie Rod.
Any advice? I have sprayed it with PB Blaster. Should I now try to replace the whole Tie Road? Unfortunately, my Haynes manual doesn't seem to have any instructions on how to do that.
I would really appreciate any advice....I am in a complete jam. Thanks!
